Does the indirect_diffuse AOV contribute at all to a light's diffuse AOV?
If so, can this be turned off somehow?
Gelöst! Gehe zur Lösung
Gelöst von Stephen.Blair. Gehe zur Lösung
A light's diffuse AOV has both the direct and indirect contribution of that light.
If you don't want the indirect, can you use the light's diffuse_direct AOV?
> world_key5Light_diffuse C<RD>.*<L.'key5Light'>
What would be the LPE for the 'diffuse_direct' ?
Thank you,
The LPE for diffuse is C<RD>.*
and diffuse_direct is C<RD>.L
so for a light group AOV it should be C<RD>.<L.'key5Light'>
Hmm,okay, so you're leaving out the asterisk on purpose, yes?
So what would be the expression for the "indirect only" for a light group AOV?
Currently, i'm using:
> "world_key5Light_diffuse_indirect C<RD>[DSVOB].*<L.'key5Light'>"but I get the feeling that's not correct...
Thank you,
Thank you,
Yes, I left of the asterisk because if I look at the built-in LPEs:
diffuse_direct = C<RD>L
diffuse_indirect = C<RD>[DSVOB].*
diffuse_indirect_key5Light would be the indirect for that light group, so your custom LPE output should match that
I see, okay, Thanks for clarifying that.
So this job is older and we're still using 5.1.0.1 on it, though newer productions
are either on 5.4.0.2 or 6.0.1.0, and it is possible we could shift version for this
particular set of shots.
So that said, using these LPEs...
>> "diffuse_direct_key5Light C<RD>.<L.'key5Light'>"
>> "diffuse_indirect_key5Light C<RD>[DSVOB].*<L.'key5Light'>"
...yield two AOV layers which are identical. Why would that be?
Thank you,
Just to add,
I've also found I get same results with 5.4.0.2 and 6.0.10.
You don't have to specify a light path expression, you can use the AOV names
And Arnold will automatically create the light group AOVs
So in an ASS file, the outputs would be
"diffuse_direct_key5Light RGB my_filter my_driver" "diffuse_indirect_key5Light RGB my_filter my_driver"
For direct, the LPE
should be
C<RD><L.'key5Light'>
The . is any event, so that includes too much
