Arnold General Rendering Forum
If I bend an object with the non-linear modifier, how can I collapse it with the object?
1 ANTWORT 1
Nachricht 1 von 2
106 Aufrufe, 1 Antwort
If I bend an object with its modifier, and then I transform it scaling (for instance), the modifier doesn't collapse to the object and I loose the bending modification.
How can I collapse or fuse to the object and then I can transform it without having to select both elements for transform it?.
Best regards.
1 ANTWORT 1
Nachricht 2 von 2
lee_griggs
als Antwort auf: Anonymous
This is an Arnold forum. Can you post this on the Maya forum please?
Lee Griggs
Arnold rendering specialist
AUTODESK
