Arnold General Rendering Forum
I textured my scene using physical material and standard target direct lights. Do I have to texture it all over again in order to render it with Arnold?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
381 Aufrufe, 2 Antworten
My scene is textured and I set lights and a camera. However, when I change it to High Quality and render it, all objets turn to black.
Is there anything I can do to solve it without having to texture everything again and start from scratch? Thank you.
Beschriftungen (5)
2 ANTWORTEN 2
Nachricht 2 von 3
madsd
als Antwort auf: Anonymous
Use the Arnold lights - only - and you are safe. ( you can use photometrics ) but just stick to the Arnold light - it also has a Skydome, - I can see you use a legacy skylight, that wont work.
You dont need to retexture your model, just delete all the lights and use pure Arnold lights and it will be fine.
Nachricht 3 von 3
als Antwort auf: madsd
Thank you!!
