Arnold General Rendering Forum
I can´t see reflection and refraction menu in Arnold, help D:
2 ANTWORTEN 2
Nachricht 1 von 3
1476 Aufrufe, 2 Antworten
When assigning a material in arnold, all the normal options appear, less reflection and refraction, as I do so that these options appear?
Beschriftungen (3)
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: Anonymous
It sounds like you think you're using Arnold 4 and the Standard shader.
With Arnold 5 and the new Standard Surface, there's no separate reflection. Just specular, which is mirror-like with roughness 0.
And refraction is now transmission.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
Ok, thanks, I just installed the new version and I did not know. Thank you
