Arnold General Rendering Forum
[HtoA] Set AOV shader with operators
1 ANTWORT 1
Nachricht 1 von 2
428 Aufrufe, 1 Antwort
Is it possible to assign an AOV shader with operators? I have an .ass file with shaders & set parameters that I'm using to assign lookdev to some geometry, and in it I also force the AOV shader to be written to the archive. When using a set parameter operator to set aov_shaders on the options node, nothing seems to happen.
selection: *.(@node == 'options')
I've tried a few of the following:
aov_shaders = '/obj/shop/AOV/cryptomatte1'
aov_shaders = '/obj/shop/AOV/*'
aov_shaders = ['/obj/shop/AOV/cryptomatte1']
aov_shaders = ['/obj/shop/AOV/*']
It doesn't seem to work. I know it's grabbing the right options node though, because things like ignore_shaders = true and xres = 100 definitely work . Putting it in the parameter slot for AOV shaders on the ROP itself doesn't do anything either. I think my syntax is probably wrong.
Am I missing something?
Thanks!
Beschriftungen (4)
1 ANTWORT 1
Nachricht 2 von 2
Stephen.Blair
als Antwort auf: Anonymous
aov_shaders is an array
and it probably has to already exist before you can set individual elements
kinda like light groups
https://answers.arnoldrenderer.com/questions/17184/operator-light-group-with-an-array-possible.html
// Stephen Blair
// Arnold Renderer Support
