Hey guys,
I would like to share a tool. Shader Transfer Tool for maya.
If you have a scene with similar char grp or mesh grp and you need to transfer mesh attributes and shaders between these, this tool will help you.
It is developed to transfer mtoa mesh attributes (Opaque, subdivision type, iterations) and shader assigned to meshes.
Link: https://knowledge.autodesk.com/community/article/230446
# Error: ImportError: file <maya console> line 62: No module named gCommon_scripts.g_common_funcs #
Hey, in g_exec_code.py file, just replace the windows path and linux path to where you have downloaded all these scripts.
it will work. Actually all these scripts are connected to that path. It is missing due to wrong path. It will work if you just put the proper path.
