Hi All, I'm trying to render additional frames to an existing render using the syntax below and can't figure out the command to render a specific frame range. Any help would be appreciated.
Dan
@echo off
REM
REM # Set Frame Count
set count=660
setlocal EnableDelayedExpansion
REM
REM # Set Scene ASS file name
set SCENE=C:\Users\drutter\Desktop\LCROSS\shot_01_ASS
REM # Set Arnold folder path
set MTOA_PATH=C:\solidangle\mtoadeploy\2019\bin
REM
REM # Set Shader Path
set SHADER_SEARCH_PATH=C:\solidangle\mtoadeploy\2019\shaders
REM
REM # Set Bin Path for Kick command
set MTOA_BIN_PATH=C:\solidangle\mtoadeploy\2019\bin
REM
REM # Kick Sequence with For Loop count
REM # Current setup below disables display window, display progressive, and has verbosity level 4
for /L %%i in (1, 1, %count%) do (
set "frame=00000%%i"
set frame=!frame:~-4!
C:\solidangle\mtoadeploy\2019\bin\kick.exe -i C:\Users\drutter\Desktop\LCROSS\shot_01_ASS\Shot_01_camera__!frame!.ass C:\Users\drutter\Desktop\LCROSS\shot_01_ASS\Shot_01_lights.ass C:\Users\drutter\Desktop\LCROSS\shot_01_ASS\Shot_01_LCROSS.ass C:\Users\drutter\Desktop\LCROSS\shot_01_ASS\Shot_01_LRO1__!frame!.ass C:\Users\drutter\Desktop\LCROSS\shot_01_ASS\Shot_01_LRO__!frame!.ass -dw -dp -v 4
-l C:\solidangle\mtoadeploy\2019\shaders
@echo off
Gelöst! Gehe zur Lösung
Gelöst von Stephen.Blair. Gehe zur Lösung
FOR /L %variable IN (start,step,end) DO command [command-parameters]
The set is a sequence of numbers from start to end, by step amount.
So (1,1,5) would generate the sequence 1 2 3 4 5 and (5,-1,1) would
generate the sequence (5 4 3 2 1)For example, for frames 3 to 16
set count=16 for /L %%i in (3, 1, %count%) do ( echo %%i )
