How to make gradient transparency
Hi. I need to make my character with gradient transparency. But I don't know how to make gradient transparency in arnold. So, the bottom part should be non transparent, and it should become transparent on the top. I tried opacity, but it was not I want. Opacity was non-showed, but I want transparent with specular.
Please help me.. I'm struggling with this T0T
+I'm using maya 2018
ben19875
Observer
Observer
Meshes in Arnold don't actually have a transparency attribute I think .
Try attach your gradient map to Transmission weight and turn on Thin walled in Geometry column , you will get something like this .
Hope it helps . Cheers
Hi. So, gradient map should be black and white, right? I try it rn, but my png file doesn't look gradient
ben19875
Observer
Observer
Can you upload some pictures of it ?
lee_griggs
Not sure which plugin you are using (MAXtoA?) but ramp -> Transmission Weight should work.
Lee Griggs
Arnold rendering specialist
AUTODESK
