How to handle transparent map? I've tried several times but not successful
result:
my demo file:
Gelöst! Gehe zur Lösung
Gelöst von madsd. Gehe zur Lösung
Try something like this.
I just used a planar UV map on the model instead of 2 material ID's to avoid having to deal with ID's but you can use ID's in a single material anyways with a switch map in addition if you realy need 2 ids.
Thank you very much, I like this method and I do it following your screenshots, the result is as follow:
How to set the parameters of "uvw map"?
@Mads Drøschler
if I want to use unwrap UVW modifier instead of UVW Map, how to do it? Do I need to modify material setup?
Try look at this post.
https://answers.arnoldrenderer.com/answers/19322/view.html
Not realy no, you can however use the UV transform node to adjust some local unwrapped tile, just note that everything inside the same UV channel is affected by the changes in the shader hirachy, you would have to isolate a certain area if you want independant control.
However, if you unwrap the head and give some polygon square a material ID 2, you can call this ID 2, as seen in the variant solution just above ( purple head ) and that can both be planar map, or advanced UNWRAP or whatever realy.
