Arnold General Rendering Forum
How to get object rotation (orientation) to change color.
1 ANTWORT 1
Nachricht 1 von 2
mz52720
517 Aufrufe, 1 Antwort
Is it possible to get object rotation or space orientation?
I would like to know what is current object orientation / rotation in space and then based on this data I would like to change the color of this arrow. Is it possible to do?
I tried to use the UV pointer to get information when an object is, for example, turned down or down. But it works quite badly.
point UV = transform("object",point(u,v,0)),
In fact I would like to build similliar shader like I have in Blender:
In Blender, Vector Transform works perfectly.
EDIT:
I wrote simple shader:
and partially it works, but its space-dependent colorization, not rotation.
x = Pos[0]-vec[0]-UV[0];
y = Pos[1]-vec[1]-UV[1];
z = Pos[2]-vec[2]-UV[2];
This code is "brute force testing", but at this moment it works quite close to this what I would like to achieve.
Tags (1)
Beschriftungen (1)
  • OSL
1 ANTWORT 1
Nachricht 2 von 2
madsd
als Antwort auf: mz52720
I would say that you could just tap into the shading normal in world space instead.
transform("world",N);
Will always return a face direction based on the face currect alignment in world space.
Next you want to take a measure of how much this normal deviates from an "up vector" normal which is a normal taken from a default position.
transform("object",N);
We also have the practical to-camera normal. Bit what you attempt to solve with "I" the hit ray.
You could use this as well.
eee.giftransform("camera,"N");
Calculate the difference and return this as a float value for hue.
Do note this needs to happen in worldspace -1 to 1. Where if your arrows point into negative space, it will be black.
www.pngSo and you want to make 3 calculations, for each axis, and rotate them.
you can use rotate(); its a core OSL function.
So that the hue position aligns on all 3 axis, and thus if you build a vector from these 3 floats, it will return the same color and make the object 1 solid color.
After this, you would want to move it into 0-1 space so you get a visual sampling the negative space.
You can also map it out to 6 debug colors, since RGB is not enough to visualize a position in space, this is why a world space normal will never show the negative direction since its not possible to derive, so you create 3 complementary colors for the negative space.
You will never be able to use only RGB only on a 360 dependant scheme, unless you compress it into 0-1 space, but that wont return RGB, it will return 50% of that in the positive space and 50% in negative space. So some artistic debug color needed.
I would use Magenta, Yellow, and perhaps Petrol green.
cc.pngOr, simply just reverse the normal so the positive lies in a normal blue/green spectrum, and the negative lies in a red/yellow.
