Arnold General Rendering Forum
how to assign texture to the specular rotation
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
excentriPMNA2
382 Aufrufe, 4 Antworten
I read the specular rotation description of arnold manual.(https://support.solidangle.com/display/A5AFMUG/Specular)
"It is possible to assign textures to the specular rotation. When doing so, it is advisable to avoid texture filtering. "
The manual explanation is not clear enough.
how can i avoid texture filtering?
4 ANTWORTEN 4
Nachricht 2 von 5
lee_griggs
als Antwort auf: excentriPMNA2
The sentence after that reads:
"This means disabling MIP-mapping and disabling the magnification filter, which by default is set to "smart bicubic." One way is to set the mipmap_bias of the image node to a strong negative value, like -8, which means "use 8 MIP levels higher resolution than usual"."
This can be found in the Arnold attributes of the Maya file node.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 5
excentriPMNA2
als Antwort auf: lee_griggs
I think that disabling MIP-mapping is to to set the mipmap_bias of the image node to a strong negative value, like -8.
but, how is to disabling the magnification filter?
what type of the Filter Type must selected?
Nachricht 4 von 5
maxtarpini
closest. but really for this kind of stuff you better get it by testing it directly with the renderer. keep AA settings low.. attach a file texture to a flat material.. set mip bias to -8 and switch between closest and any 'bi'xxx filter.. you'll see in an instant what filters your texture and what not.
Nachricht 5 von 5
excentriPMNA2
thank you very much
