Arnold General Rendering Forum
How to adjust this uvw map?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
552 Aufrufe, 4 Antworten
this is my current map:
below is what I want:
Question:
How to adjust it to what I want?
egg-3dsmax2020.zip
Tags (1)
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
madsd
als Antwort auf: Anonymous
Try this
Attached the updated scene.
You forgot to set the bitmaps to Default wrapping.
And you control the UV's with the UV transform node, connected to the textures UV lookup slot.
Nachricht 3 von 5
madsd
Also,
You can simplify by grabbing the alpha from the png file directly, and delete the additional alpha map.
Nachricht 4 von 5
als Antwort auf: madsd
I downloaded "egg-3dsmax2020.zip(180.4 kB)",
the map is on both sides of outside and inside:
How to remove the redundant three ones?
Nachricht 5 von 5
madsd
Attached the Material ID version from the other thread which takes care of it automatically.
You basically just introduce a selective area on the mesh, the ID you set up. Then pipe the shader up to that channel slot in the RGBA Switch node which is second slot which is the second channel. So quite logic.
