Arnold General Rendering Forum
How do I access the polymesh of a scene from a custom procedure node?
2 ANTWORTEN 2
Nachricht 1 von 3
251 Aufrufe, 2 Antworten
mtoa 2.0.1
Arnold core 5.0.1.0
I'm trying to create a custom procedural node.
The aim is to create a new polymesh as a guide of polymesh of a specific name in the scene. However, when accessing the data of specified polymesh from init () or get_node () of Procedural API, NULL is returned in many cases. Occasionally, "vlist" or "nsides" is returned correctly, but I do not know the reason.
Does anyone know the right way?
Code example
	procedural_init
		AtString obj_name = AiNodeGetStr( node, "object" );
		AtNode* pNode = AiNodeLookUpByName( obj_name );
		AtArray* pSideArray = AiNodeGetArray( pNode, "nsides" );
		int nSides = AiArrayGetNumElements( pSideArray );
	procedural_get_node
		Instancer* pInstancer = (Instancer*)user_ptr;
		AtNode* pObj = pInstancer->objects[i];
		if( AiNodeIs(pObj, AtString("polymesh")) )
			AtArray* pVIdxArray = AiNodeGetArray( pObj, "vidxs" );
			int nPolys = AiArrayGetNumElements( pVIdxArray );
			AtArray* pVerts = AiNodeGetArray( pObj, "vlist" );
			int nVerts = AiArrayGetNumElements( pVerts );
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: Anonymous
Those arrays (like vlist) are destroyed during the render process, where the data is transformed and stored internally in an optimized way. If you want the render to avoid deleting those arrays, you have to create the render session as interactive: AiBegin(AI_SESSION_INTERACTIVE);
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
@Stephen Blair
Thanks for answering, stephen.
I was very helpful about the internal behavior of Arnold. Since the core version I am using is 5.0.1, I will verify with version 5.1 or higher, which can use the instructed API.
By the way, I'd like to ask because I do not have help etc, but is there any disadvantage in interactive mode compared to normal mode?
I use it with mtoa, but it seems that using with maya_batch can not be done easily without script customization.
Thank you.
