Arnold General Rendering Forum
how can enable gpu rendering instead of cpu rendering......while rendering my cpu reached to its max 100% usage and my gpu always remains at 0% .....i want to render my files using gpu... how can i do it...
5 ANTWORTEN 5
Nachricht 1 von 6
rakeshkanu1996_rk
661 Aufrufe, 5 Antworten
Beschriftungen (3)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: rakeshkanu1996_rk
You need to use a different render engine like Redshift, Octane, or V-Ray (Limited)
Nachricht 3 von 6
@james Robinsons that means i cannot render in arnold using gpu ..
Nachricht 4 von 6
Arnold GPU hasn't been released yet, when it is released, you'll be able to render on the GPU. But the current versions of Arnold only render from the CPU.
Nachricht 5 von 6
You can try to sign up for the private beta of Arnold GPU here: https://feedback.autodesk.com/key/ARN0LD
Nachricht 6 von 6
