Arnold General Rendering Forum
heavy banding with texture
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
froszu
1111 Aufrufe, 8 Antworten
I'm experiencing heavy banding with a particular texture. Please take a look at attached screenshot, it shows a plane with surfaceShader (no lighting).
-left: a texture as seen in XnView (png file),
-center: renderview with Arnold rendering (banding artifacts) and
- right: 3delight render (correct rendering for comparision).
Other facts:
- rendering arnold to mayaRenderView or arnoldView gives banding
- rendering arnold to EXR gives banding
- rendering with 3delight to mayaRenderView gives banding (same as arnold)
- rendering with 3delight to EXR or 3delightDisplay gives correct result
I have colormanagement enabled with setting shown on screenshot.
It seems bading goes away if I disable colormanagement but this is not a solution.
Can anyone recommend any steps with this problem?
8 ANTWORTEN 8
Nachricht 2 von 9
What colorspace is your texture set to in maya? It should be set to sRGB.
Ashley Handscomb Retallack
Senior Software Engineer (Arnold)
Arnold Documentation | Arnold Downloads
Nachricht 3 von 9
froszu
als Antwort auf: froszu
It is set to sRGB. I also tried with manually converting to .tx with proper colorspace settings. I get the same results
Nachricht 4 von 9
zenop
Converting the texture to 16 bit will most likely solve the issue, I'm curious why this is necessary though, since the banding isn't visible in the base texture.
Nachricht 5 von 9
froszu
I tried converting it to 32bit exr, in photoshop. Nothing..
I believe it has smth to do with maya color space handling.
Nachricht 6 von 9
froszu
OK, COnverting to 16bit tiff, in photoshop workarounds the issue.
However something seems to be wrong with maya.
Nachricht 7 von 9
froszu
Problem can be solved manually converting to .tx with a "-d float" option.
Default seems to be 8bit, hence quantization noise.
Nachricht 8 von 9
froszu
Is there any method to globally disable auto conversion for textures ?
Nachricht 9 von 9
you can disable auto-tx generation globally: https://support.solidangle.com/x/EAxkAg Only wise to do this if you are managaging the conversion and use of the tx files yourself
