Is it possible to turn off the reflection of my HDR (from skydome) on glass?
I can put the transmission to 0 but that does not stop the reflection.
With the IOR on the glass it looks very odd and I am happy with the reflections on other surfaces but not the window
thank you
Gelöst! Gehe zur Lösung
Gelöst von lee_griggs. Gehe zur Lösung
What if you reduce Specular Visibilility?
turn specular off from arnold render settings->environment settings->specular off (at list in 3ds max, this is how I do it)
Thank you for the replies (likes given and one answer accepted).
Between specular visibility and IOR I can get a good solution
Unfortunately there is no option available on Environment (thank you for the suggestion) - see attachedscreen-shot-2018-01-25-at-083845.png
