Hi
I have a single plane which has an aistandardshader with glass properties. The IOR = 1.5 and I get a very curved view when looking through the glass.
It may be correct but it looks really odd when I view from inside the space.
In the image there is a red coloured plane outside of the window and there is a portal, a directional light and an area light.
Do I just reduce the IOR or something else so it looks less refracted or is this the right way to do it?
thank you
Gelöst! Gehe zur Lösung
Gelöst von maxtarpini. Gehe zur Lösung
That's definitively not the right way to do it ![]()
The fix is simple however, under 'Geometry' rollout (aiStandardSurface) check 'Thin Walled'.
I'd go also in the Shape tab of your plane and under Arnold->Visibility uncheck all but Primary Visibility.
