Filtered Depth AOV
Filtered Depth AOV
paul.sheehyECZEJ
Filtered Depth AOV
paul.sheehyECZEJ
To get a clean, filtered depth AOV, is the best way to add the standard Z one and then to change its filter from closet to gaussian?
I just want to use this for a basic fog pass in Nuke and wondering which is the best way to generate it.
paul.sheehyECZEJ
@ Stephen Blair, would you have any ideas on this one? It's just that we are against the clock on it and need all renders by this Friday.
Cheers Stephen 🙂
Paul
Stephen.Blair
It's up to you. By default the Z AOV uses the closest filter, but if you want anti-aliasing then you can set the filter to gaussian.
// Stephen Blair
// Arnold Renderer Support
paul.sheehyECZEJ
I was just unsure of the proper way to go about it. I will use this method though
paul.sheehyECZEJ
Is it not possible to add the two Z AOVs (filtered and unfiltered) into the same list of AOVs?
