Arnold General Rendering Forum
Facing Issues while loading xgen procedural.dll in standin.
3 ANTWORTEN 3
Nachricht 1 von 4
461 Aufrufe, 3 Antworten
As per documentation, Arnold provides path(dso) and data attribute on standin to allow loading custom procedurals and their flags but while trying to load xgen_procedural.dll in path and passing required flags in data attribute it's showing me below error.
WARNING |   [proc] aiStandInShape: don't know how to load .../xgen_procedural.dll
Any suggestions for what I might be missing?
3 ANTWORTEN 3
Nachricht 2 von 4
Stephen.Blair
als Antwort auf: Anonymous
dso? You're looking at the old Arnold 4 documentation. The procedural nodes loads ass files only. Something like xgen_procedural is an xgen_procedural node.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 4
Hi Stephen,
Thanks for the quick response...
Adding further clarification to make myself clear, I am using Arnold 5 mtoa 3.x and inside the data attribute (inside extra attribute section) of standin, I am calling below flags and values to pass my xgen file.
setAttr ".data" -type "string" "-debug 1 -warning 1 -stats 1  -frame 75.000000  -file E:/RnD/xgen/workflow_development/AiStandin/sphere__collection.xgen -palette collection -geom E:/RnD/xgen/workflow_development/AiStandin/sphere__collection.abc -patch pSphere1 -description description -fps 24.000000  -motionSamplesLookup 0.0  -motionSamplesPlacement 0.0  -world 1;0;0;0;0;1;0;0;0;0;1;0;0;0;0;1";
Then inside the path attribute(which internal name is .dso) I am calling specified procedural.dll file. (File browser gives the option to select ether Arnold archives/Arnold procedurals file type.)
setAttr ".dso" -type "string" "C:/solidangle/mtoadeploy/2019/procedurals/xgen_procedural.dll";
And Yes, As you mentioned it used to work fine in Arnold 4 but I am not aware how to replicate the same for Arnold 5.
Basically, I am trying to avoid baking ass files sequence here. instead, I was trying to pass procedurals flags and required procedurals path.
I would appreciate the help..!!
Nachricht 4 von 4
Stephen.Blair
In Arnold 5 and later, xgen_procedural is a node. So this is what is exported:
xgen_procedural
 name /collection/description/descriptionShape
 visibility 255
 matrix
 1 0 0 0
 0 1 0 0
 0 0 1 0
 0 0 0 1
 id 3738019217
 data "-debug 1 -warning 1 -stats 1  -frame 21.000000  -file C:/Users/Stephen Blair/Documents/maya/projects/default/scenes/xgen_archives__collection.xgen -palette collection -geom C:/Users/Stephen Blair/Documents/maya/projects/default/scenes/xgen_archives__collection.abc -patch pPlane1 -description description -fps 24.000000  -interpolation linear  -motionSamplesLookup 0.0  -motionSamplesPlacement 0.0  -world 1;0;0;0;0;1;0;0;0;0;1;0;0;0;0;1"
 declare dcc_name constant STRING
 dcc_name "descriptionShape"
 declare xgen_shader constant ARRAY NODE
 xgen_shader "lambert1"
 declare irRenderCam constant STRING
 irRenderCam "false,38.357384,38.285717,70.352417"
 declare irRenderCamFOV constant STRING
 irRenderCamFOV "54.432224,36.288151"
 declare irRenderCamXform constant STRING
 irRenderCamXform "0.877983,-0.206371,0.431922,0.000000,0.000000,0.902297,0.431115,0.000000,-0.478692,-0.378512,0.792201,0.000000,0.000000,0.000000,-88.806236,1.000000"
 declare irRenderCamRatio constant STRING
 irRenderCamRatio "1.500000"
 declare xgen_renderMethod constant STRING
 xgen_renderMethod "1"
 declare ai_mode constant INT
 ai_mode 0
 declare ai_min_pixel_width constant FLOAT
 ai_min_pixel_width 0
 declare xgen_multithreading constant BOOL
 xgen_multithreading off
A standin is a procedural node, not an xgen_procedural node.
// Stephen Blair
