Arnold General Rendering Forum
Displacement Shader MtoA
5 ANTWORTEN 5
Nachricht 1 von 6
561 Aufrufe, 5 Antworten
I am trying out displacement (Maya 2018 Arnold 5) and I have a simple test image (32bit Tiff). The results I get from the render look a bit so I guess I am missing something.
The render is attached and the hypershade set up. It is on a plane with a high polycount.
On the support notes it shows Subdivisions with iterations and adaptive metric etc. (image attached) but I can't find this setup in Maya or in Arnold so I am at a bit of a loss.
thank youscreen-shot-2018-02-08-at-101719.pngscreen-shot-2018-02-08-at-101555.pngscreen-shot-2018-02-08-at-101701.png
Tags (1)
Beschriftungen (1)
  • MtoA
5 ANTWORTEN 5
Nachricht 2 von 6
lee_griggs
als Antwort auf: Anonymous
They are in the Arnold attributes of the mesh.
Be careful when increasing the number of iterations on a high poly mesh as it can generate a lot of polys.
Did you set the file texture to 'RAW'?
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 6
@Lee Griggs
thank you
yes the 32bit tif is set to raw. I still have an issue with this as it shows an odd render on the height (a shaded area that is not there). I set the scale down to 0.05 but not sure how to clean this up and make it sharper as per the example in the docs.
thank you again for the help (liked and rewarded)
Nachricht 4 von 6
lee_griggs
Is the image being displayed 1:1 in the render view?
Can you share the scene?
Lee Griggs
AUTODESK
Nachricht 5 von 6
displace.zip
thank you for your time. Scene file and tiff attached
very much appreciated
Nachricht 6 von 6
@Lee Griggs
Ok I think after reading the docs and fixing stuff I have an answer.
Auto Bump off and catclark as type
thank you again for you help earlier
