Displacement...........help pls
Message 1 of 21
Replies (20)
Message 2 of 21
Stephen.Blair
MORE what?
Check the settings in the displacement shader node.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 21
it this???
Message 4 of 21
Stephen.Blair
Reduce the Scale and see if that helps
// Stephen Blair
Message 5 of 21
No (((((((((
Message 6 of 21
it does not show displacement map
Message 7 of 21
Stephen.Blair
Does that displacement map have an alpha channel? Maybe you need to enable Alpha is Luminance.
// Stephen Blair
Message 8 of 21
included(
Message 9 of 21
Stephen.Blair
What's the expected result?
Did you check the Arnold log?
// Stephen Blair
Message 10 of 21
the same, it was included
Message 11 of 21
I took everything on this site http://gl.ict.usc.edu/Research/digitalemily2/
Message 12 of 21
Stephen.Blair
I do not understand.
// Stephen Blair
Message 13 of 21
here is the result
Message 14 of 21
are there any other options?
Message 15 of 21
lee_griggs
Is the displacement.exr set to RAW? Also, try adjusting the Scalar Zero Value.
Lee Griggs
Arnold rendering specialist
AUTODESK
Message 16 of 21
Haven't watched it properly, but this might help you: https://www.youtube.com/watch?v=ss13J1emsvw
It's the same model + maps and while scrubbing through the video, I saw that there was a displacement connection going on. Check it out, it might help you with your issue.
As a general rule of thumb, Arvids tutorials are always a great resource on shading with The Arnold.
Message 17 of 21
Yes, Scalar makes the model smaller, but displacement not working
Message 18 of 21
I do the same thing, and the result is not the same as in the video, so I am writing here because I do not know what to do.
Message 19 of 21
lee_griggs
Can you upload the scene?
Lee Griggs
AUTODESK
Message 20 of 21
How, i never did it, file maya mb?
