Arnold General Rendering Forum
Differentiate between instances when using AiTrace()
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
zenop
352 Aufrufe, 2 Antworten
Is it possible to differentiate between instanced objects when getting AtScrSample->obj using AiTrace()?
Or if this is not the way to do it (which I assume, since I cannot differentiate between two instanced objects here), how should I go about this? Ideally I want different hit data per instance.
Ty!
Z
Tags (2)
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: zenop
@Zeno Not sure, I have to ask around.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
zenop
It seems like I should use AiTraceProbe() and compare the sg->Op instead.
