dichroic glass
dichroic glass
dichroic glass
How would I set up a dichroic glass pane, which is changing colour dependant on viewing angle and also surface caustics are in the opposite colour than transmission dependant in light angle?
Shawn_Kearney1
Use facing ratio as the mix amount of an "mix-" or "layer-" rgb node. I am not sure about the caustics, however. Are you talking about caustics or surface reflections, though?
lee_griggs
I attached a Thin Film shader to the Transmission here:
Lee Griggs
Arnold rendering specialist
AUTODESK
