Arnold General Rendering Forum
deepexr append error
4 ANTWORTEN 4
Nachricht 1 von 5
1001 Aufrufe, 4 Antworten
Hi
When resuming an aov with append and tiled deep exr we constantly get this error:
[driver_deepexr] test_aiAOVDriver@driver_deepexr.test: Failed deep OpenEXR2 write in tiled mode: Failed OpenEXR write: Failed to write pixel data to image file ... Attempt to write tile (15, 39, 0, 0) more than once.
Running Arnold 5, MTOA 2.0.2, 2017 update 4 on linux
Tiled, append and subpixel merge are ticked on in the AOV.
Any ideas?
Thank you
driver_deepexr
 name test_aiAOVDriver@driver_deepexr.test
 filename ...
 tiled on
 append on
 subpixel_merge on
 use_RGB_opacity off
 alpha_tolerance 0.25
 depth_tolerance 1
 alpha_half_precision on
 depth_half_precision off
 layer_tolerance 10
 layer_half_precision 1
Tags (2)
Beschriftungen (2)
4 ANTWORTEN 4
Nachricht 2 von 5
Stephen.Blair
als Antwort auf: Anonymous
My first tests didn't repro this.
What stops the render?
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 5
test.assoutput-deepexr.zip
Hi
I've attached ass and failed append exr.
I'm manually killing the render to test the append
If you need anything else let me know
Thank you
Nachricht 4 von 5
Hi
Does the attached .ass work for you to kick? (second try, when appending)
Thank you
Nachricht 5 von 5
ashley.handscomb.retallack
I can confirm that this example does replicate the problem. Looking in to it further for you now.
Ashley Handscomb Retallack
Senior Software Engineer (Arnold)
Arnold Documentation | Arnold Downloads
