Arnold General Rendering Forum
Crash with production rendering
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
cerakecera
461 Aufrufe, 7 Antworten
Thanks alot for the new version and the optimized denoiser/imager!
But i encountered an issue when using Production mode. Wanted to render a sequence with the GPU and had a Max crash on first frame. After couple crashes later i enabled log to get the error. Tried again with CPU and same problem.
As far as i understand the log, it couldnt load a plugin.
7 ANTWORTEN 7
Nachricht 2 von 8
CiroCardoso3v
als Antwort auf: cerakecera
Are you using TX files? Looking at your log, I can see 42 textures not tiled or mip/mapped.
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Nachricht 3 von 8
cerakecera
als Antwort auf: CiroCardoso3v
Hi Ciro :leicht_lächelndes_Gesicht:
Yes all tx. I had to delete the entries in the "Image file statistics" for discretion
But all textures have a tx version and are loaded without error
Nachricht 4 von 8
CiroCardoso3v
Are you using OSL bitmaps by any chance?
Ciro Cardoso
Nachricht 5 von 8
cerakecera
Yes
Nachricht 6 von 8
CiroCardoso3v
First think I would do is convert all the OSL Bitmaps to Arnold Images. I think Mads' Arnold Converter has an option for that.
Ciro Cardoso
Nachricht 7 von 8
CiroCardoso3v
Instead of using the ARV, for now render with the standard 3ds Max frame buffer.
Ciro Cardoso
Nachricht 8 von 8
cerakecera
That did it, thanks!
