Greetings,
Is there a standard way to replicate Corona’s very handy UV randomization shader when a material is tiled with Arnold in C4D? Per object randomization is easy but what about material repetition at the same object eg. a marble checkerboard floor plane where each tile should be different .
I just came up against this problem recently, I couldn't seem to get the original 3dsmax osl shader to work but this one modified and written for redshift worked
RedshiftOSLShaders/TextureNoTile.osl at main · redshift3d/RedshiftOSLShaders (github.com)
// Non-Tiling Texture Shader // TextureNoTile.osl, by Zap Andersson // Modified: 2020-03-28 // Copyright 2020 Autodesk Inc, All rights reserved. This file is licensed under Apache 2.0 license // https://github.com/ADN-DevTech/3dsMax-OSL-Shaders/blob/master/LICENSE.txt // Modified by Saul Espinosa for Redshift OSL Support 2020-12-28 float sum( color col ) { return col[0]+col[1]+col[2]; } color textureNoTile( string FileName, point UV, float GradientScale, float Offset, float Rescale, float Rotate, int LevelCount, int Debug, int Seed ) { float k = noise("uperlin", UV / GradientScale, Seed); float l = k*LevelCount + UV[1] / GradientScale; float i = floor( l ); float f = l - i; vector offa = cellnoise(i + 0.0, Seed) * vector(Offset, Offset, 1.0); vector offb = cellnoise(i + 1.0, Seed) * vector(Offset, Offset, 1.0); float sca = 1.0 / (1.0 + (offa[2] - 0.5) * Rescale); float scb = 1.0 / (1.0 + (offb[2] - 0.5) * Rescale); float rota = offa[2] * Rotate; float rotb = offb[2] * Rotate; point rotA = rotate(UV, rota, vector(0.5,0.5,0), vector(0.5,0.5,1.0)); point rotB = rotate(UV, rotb, vector(0.5,0.5,0), vector(0.5,0.5,1.0)); color cola = texture(FileName, rotA[0] * sca + offa[0], 1.0 - (rotA[1] * sca + offa[1]), "wrap", "periodic" ); color colb = texture(FileName, rotB[0] * scb + offb[0], 1.0 - (rotB[1] * scb + offb[1]), "wrap", "periodic" ); if (Debug) { cola = offa; colb = offb; } return mix( cola, colb, smoothstep(0.1,0.9,f-0.1*sum(cola-colb)) ); } shader NoTile [[ string help = "Non-Tiling Bitmap Lookup, based on an OpenGL Technique", string label = "Non-Tiling Bitmap Lookup", string URL = "http://www.iquilezles.org/www/articles/texturerepetition/texturerepetition.htm" ]] ( // Texture Input point uvw = point(u,v,0) [[ string label= "UV Coordinate", string help = "The 2D coordiante at which the texture is looked up." ]], string Filename = "" [[ string widget="filename", string page = "Image" ]], string fromSpace = "" [[ string label = "Input Space", string widget = "colorspace", string page = "Image"]], string toSpace = "" [[ string label = "Output Space", string widget = "colorspace", string page = "Image"]], float gainMul = 1 [[ string label = "Gain", string page = "Image", float softmin = 0, float softmax = 10, float slidermin = 0, float slidermax = 10, float sensitivity = 0.001 ]], // Noise Options float GradientScale = 2.0 [[ float min = 0, float max = 25, string page = "Noise" ]], float Offset = 1.0 [[ float min = 0, float max = 25, string page = "Noise" ]], float Rescale = 0.0 [[ float min = 0, float max = 25, string page = "Noise" ]], float Rotate = 0.0 [[ float min = -180, float max = 180, string page = "Noise" ]], int LevelCount = 8 [[ int min = 0, int max = 25, string page = "Noise" ]], int Seed = 0 [[ int min = 0, int max = 100, string page = "Noise" ]], int Debug = 0 [[ string widget = "checkBox", string help = "Shows the regions that are being mixed", string page = "Utility" ]], int Bypass = 0 [[ string widget = "checkBox", string help = "Turns the effect off, to compare", string page = "Utility" ]], output color outColor = 0 ) { int s = Seed; point Pos = select(vector(u,v,0), uvw, isconnected(uvw)); if (Bypass) color Col = texture(Filename, Pos[0], 1.0 - Pos[1], "wrap", "periodic"); else Col = textureNoTile( Filename, Pos, GradientScale, Offset, Rescale, Rotate, LevelCount, Debug, s ); outColor = transformc( fromSpace, toSpace, Col) * gainMul; }
