Arnold General Rendering Forum
Convert AiStandardSurface to Lambert/Phong/Blinn (BaseColor)
5 ANTWORTEN 5
Nachricht 1 von 6
3285 Aufrufe, 5 Antworten
Is there any way (Mel/Python...) to convert a AiStandardSurface material to a Lambert/Phong/Blinn and still mantain material color properties?
Beschriftungen (5)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
I've used this script:
//change all phong Materials to aiStandard Material
// If you need to change another Material, simple  change `ls -type "phong"`
    string $newMaterialType = "aiStandard";
    string $nm = `createNode $newMaterialType`;
    string $ms[] = `ls -type "blinn"`;
    string $pa[] = `listAttr -visible -settable -scalar $ms`;
    string $nma[] = `listAttr -visible -settable -scalar $nm`;
    string $ca[] = stringArrayRemove($nma, $pa);
        $ca = stringArrayRemove($ca, $pa);
    delete $nm;
    string $a; string $m; float $v; string $cl[];
    for ($m in $ms)
        $cl = `listConnections -destination true -plugs true -source false -type shadingEngine $m`;
        connectAttr -f ($nm + ".outColor") ($cl);
        for ($a in $ca)
            $v = `getAttr ($m + "." + $a)`;
            catchQuiet(`setAttr ($nm + "." + $a) $v`);
        delete $m;
to convert a blinn to arnold, and it does work, so i tried the other way:
    string $newMaterialType = "blinn";
    string $ms[] = `ls -type "aiStandard"`;
    delete $nm;
    for ($m in $ms)
        for ($a in $ca)
        delete $m;
I've also tried "aiStandardSurface" instead of "aiStandard"
But this doesnt work...
i get this error:
// Error: line 18: The destination attribute '' cannot be found. //
Nachricht 3 von 6
lee_griggs
Just curious as to why you would want to do this?
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 4 von 6
als Antwort auf: lee_griggs
Because i have a lot of objects with arnold materials (The project im working on was supposed to be a short) but now they also want a very simple unity project to show the models(Most of them can be flat colors without textures, they just need to see the model itself) and if i export an fbx with arnold materials, it does export the materials but when i do import them in unnity, the flat color is grey, instead of the ones the aiStandardSurface has
Nachricht 5 von 6
Just in case anyone was wondering how.
This is how a friend (Github: @PRZurro) managed to convert just the BaseColor of a aiStandardSurfaceLegacy Shader to the Color of Legacy Shader
string $newMaterial = `createNode $newMaterialType`;
string $oldMaterials[] = `ls -type "aiStandardSurface"`;
string $oldMaterialsAttr[] = `listAttr -visible -settable -scalar $oldMaterials`;
string $newMaterialAttr[] = `listAttr -visible -settable -scalar $newMaterial`;
string $ca[] = stringArrayRemove($newMaterialAttr, $oldMaterialsAttr);
$ca = stringArrayRemove($ca, $oldMaterialsAttr);
delete $newMaterial;
string $a; string $b; string $m; float $v; string $cl[];
for ($m in $oldMaterials)
    connectAttr -f ($newMaterial + ".outColor") ($cl);
    for ($a in $ca)
        catchQuiet(`setAttr ($newMaterial + "." + $a) $v`);
    float $colorR = `getAttr($m + ".baseColorR")` ;
    catchQuiet(`setAttr ($newMaterial + ".colorR") $colorR`);
    float $colorG = `getAttr($m + ".baseColorG")` ;
    catchQuiet(`setAttr ($newMaterial + ".colorG") $colorG`);
    float $colorB = `getAttr($m + ".baseColorB")` ;
    catchQuiet(`setAttr ($newMaterial + ".colorB") $colorB`);
    delete $m;
Nachricht 6 von 6
laomusic_arts
Hi!
Here i what I do to convert an "Arnold scene" to a "Standard Maya shaders scene":
  • save the scene as SceneNameFBX
  • open the Hypershader and graph the shader
  • create a blinn material and name it
  • plug your maps into the blinn
  • convert any "strange" Arnold shader to texture (aiRamp, aiColorCorrect, remapColor etc...) in Hypershader Menu Edit > Convert to File Texture
  • change the render to Maya Software
  • export as FBX and copy the textures ino this same folder
  • repeat the above procedure for DAE(Collada) & OBJ formats
  • Be happy!
Hope this helps!
LAO
