I'm trying to render an .ass sequence using the following from a previous question but it overwrites the first frame every time. Does anyone have some command line syntax for rendering a frame sequence?
REM # Kick Sequence with For Loop count
REM # Current setup below disables display window, display progressive, and has verbosity level 4
for /L %%i in (1, 1, %count%) do (
set "frame=000000%%i"
set frame=!frame:~-4!
%MTOA_BIN_PATH%\kick.exe -i %SCENE%.!frame!.ass -l %SHADER_SEARCH_PATH% -dw -dp -v 4
Put in an echo command to check what commands are generated. If that looks ok, then what are the output filenames in the ass file?
echo %MTOA_BIN_PATH%\kick.exe -i %SCENE%.!frame!.ass -dw -dp -g 2.2 -v 4
Hi Stephen, I figured it out. The set frame command literally wanted me to insert that same .!frame!. into the input file name. Seems obvious now. Thanks for your help.
