Arnold General Rendering Forum
Combining Normal and Height
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
399 Aufrufe, 7 Antworten
In the example here: https://support.solidangle.com/display/A5AFMUG/Combining+Normal+and+Bump+Maps
It has the normal map as sRGB and alpha is luminance. Is this correct or should it be Raw and alpha is luminance
I have set up in the same way but get a much darker result when set to sRGB
thank you
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Simple rules:
textures acting as color should be set to sRGB
textures acting as data should be set to RAW
Nachricht 3 von 8
@rachid Hadj Abderrahmane
thanks (liked and rewarded)
I am unsure here if a Normal map is color or data given it has color but acts as data?
Nachricht 4 von 8
normal map, bump map, displacement map: are data saved in RGB channel
Nachricht 5 von 8
Do you mean Raw?
thanks
Nachricht 6 von 8
like I sad any texture acting as data must be set to RAW
bump, normal, displacement, specular map roughtness map must be set to RAW
one exception: specular map if it act as color must be set to sRGB otherwise RAW
Nachricht 7 von 8
thank you. Interesting that the solid angle example (above) the normal is set to sRGB
thanks again
Nachricht 8 von 8
I think that's was the old tutorial, before Color Management
