I am writing voronoi cell noise for Arnold Maya in C++ for study by reading Advanced Renderman.
Although Writing fbm noise was easily done, I am stuck on creating voronoi cell noise for long time..
I could compile the voronoi cell noise, but it affects nothing in Maya.
The following is the code. I hope someone know what caused the issue.
Also, it would be really awesome if you could give some advice to me since I am still a beginner in C++ and don't know if I could convert all the code from Renderman to Arnold properly.
#include <ai.h>
AI_SHADER_NODE_EXPORT_METHODS(cellNoiseMtd);
enum cellNoiseParams { p_jitter };
node_parameters
AiParameterFlt("jitter", 0.5);
node_initialize{}
node_update{}
node_finish{}
float voronoi_f1_3d(AtVector PP, float jitter)
AtVector thiscell;
AtVector testcell;
AtVector pos;
AtVector offset;
float f1, dist;
AtVector pos1;
thiscell = (floor(PP.x) + 0.5, floor(PP.y) + 0.5, floor(PP.z) + 0.5);
f1 = 1000;
float i, j, k;
for (i = -1; i <= 1; i += 1) {
for (j = -1; j <= 1; j += 1) {
for (k = -1; k <= 1; k += 1) {
testcell = thiscell + (i, j, k);
pos = testcell + jitter * (AiCellNoise3(testcell) - 0.5);
offset = pos - PP;
dist = 0.5; //This line was originally "float dist = offset.offset;" in Advanced Renderman, but I really couldn't find how this can be converted properly for Arnold Maya, so please let me know if someone know the solution.
if (dist < f1) {
f1 = dist; pos1 = pos;
f1 = AiSqr(f1);
return f1;
shader_evaluate
float jitter = AiShaderEvalParamFlt(p_jitter);
AtVector PP;
PP = sg->P;
sg->out.RGB() = voronoi_f1_3d(PP, jitter);
You can replace:
by:
dist = AiV3Dot(offset, offset);
There's loads of implementations of this specific noise pattern online for you to look at, e.g: https://github.com/sambler/osl-shaders/blob/master/lib/noises_osl.h#L190
You can also use the AiCellular function in the procedural texturing API to do this more easily. And if you're just looking for voronoi cells, I believe that's what the flakes shader uses under the hood. Just turn the density up.
Thank you very much for your advice!!
AiCellular function looks extremely useful, but since I am such a beginner in writing shaders and don't know much about C++, I've just got stuck on how to use AiCellular function.. I googled about void function, but I haven't figured out how I can implement AiCellular function into the code...
Please help me if you already have used the function before.
When it comes to the flakes shader, I tried and found this is what I was looking for!! I will definitely use in the near future, but for now I would like to write the shader one in order to get used to coding shaders in C++.
The link is really great for my study!! I will read it this weekend:)
