Arnold General Rendering Forum
can someone explain how I can add opacity to a utility shader?
5 ANTWORTEN 5
Nachricht 1 von 6
Joshgeorge1971_Joshgeorge1971
1266 Aufrufe, 5 Antworten
,if I want to create a custom AOV but use the opacity matte that I have plugged into the standard surface..I cant work it out at all..I am sure it must be pretty simple but i am really stuck...SItoA by the way thanks,Hi ..having an issue with Utility shader and Opacity..
Tags (1)
Beschriftungen (1)
  • aov
5 ANTWORTEN 5
Nachricht 2 von 6
Maya user here with Arnold 4.x;
I have an opacity slot in my Arnold utility shader that works flawlessly.
Stupid question: Have you un-ticked the "opaque" option in the Arnold settings in the shape? I'm sure there is some equivalent in SI; in Maya you have to tell Arnold that a specific model has transparency, otherwise transparency does not work with that object.
Nachricht 3 von 6
hi thanks for the reply..just switched to arnold 5..and the opacity slot has been removed..yes 'opaque' is off ??
Nachricht 4 von 6
I just checked in 5.0 an indeed the opacity slot is gone.
Just plug the utility shader in the "out color" slot of a surface shader and connect the transparency map to the "out transparency". That works for me here.
Nachricht 5 von 6
Hi..so this works..but it does feel a bit clunky, having to use standard surface and a custom AOV just to get opacity on a flat shader..if anyone knows a more simple approach please let me know..thanks for the help so far
Nachricht 6 von 6
dzone1
als Antwort auf: Anonymous
Test comment.
