I would like to use the Arnold renderer SDK with SFML 2.5.1. Is this possible?
Gelöst! Gehe zur Lösung
Gelöst von Stephen.Blair. Gehe zur Lösung
Why not? We use the Arnold SDK with the Maya sdk, the 3ds Max sdk, the Houdini sdk, the Katana sdk. And others use it with Blender and Gaffer and Softiamge
Thank you. My question is really how can I use it.
I want to render on an SFML window instead to a JPEG. Here is my code:
I want to render the Arnold output on an SFML window I defined below:
(Please excuse me, I am new to C++)
#include <ai.h>
#include <SFML/Graphics.hpp>
class SFMLWindow {
public:
int show(AtArray *arrayOutput) {
// create the window
sf::RenderWindow window(sf::VideoMode(800, 600), "My window");
// run the program as long as the window is open
while (window.isOpen())
// check all the window's events that were triggered since the last iteration of the loop
sf::Event event;
while (window.pollEvent(event))
// "close requested" event: we close the window
if (event.type == sf::Event::Closed)
window.close();
// clear the window with black color
window.clear(sf::Color::Black);
// draw everything here...
// window.draw(arrayOutput);
// end the current frame
window.display();
return EXIT_SUCCESS;
int main()
// start an Arnold session, log to both a file and the console
AiBegin();
AiMsgSetLogFileName("scene1.log");
AiMsgSetConsoleFlags(AI_LOG_ALL);
// create a sphere geometric primitive
AtNode *sph = AiNode("sphere");
AiNodeSetStr(sph, "name", "mysphere");
AiNodeSetVec(sph, "center", 0.0f, 4.0f, 0.0f);
AiNodeSetFlt(sph, "radius", 4.0f);
// create a polymesh, with UV coordinates
AtNode *mesh = AiNode("polymesh");
AiNodeSetStr(mesh, "name", "mymesh");
AtArray* nsides_array = AiArray(1, 1, AI_TYPE_UINT, 4);
AiNodeSetArray(mesh, "nsides", nsides_array);
AtArray* vlist_array = AiArray(12, 1, AI_TYPE_FLOAT, -10.f, 0.f, 10.f, 10.f, 0.f, 10.f, -10.f, 0.f, -10.f, 10.f, 0.f, -10.f);
AiNodeSetArray(mesh, "vlist", vlist_array);
AtArray* vidxs_array = AiArray(4, 1, AI_TYPE_UINT, 0, 1, 3, 2);
AiNodeSetArray(mesh, "vidxs", vidxs_array);
AtArray* uvlist_array = AiArray(8, 1, AI_TYPE_FLOAT, 0.f, 0.f, 1.f, 0.f, 1.f, 1.f, 0.f, 1.f);
AiNodeSetArray(mesh, "uvlist", uvlist_array);
AtArray* uvidxs_array = AiArray(4, 1, AI_TYPE_UINT, 0, 1, 2, 3);
AiNodeSetArray(mesh, "uvidxs", uvidxs_array);
// create a red standard surface shader
AtNode *shader1 = AiNode("standard_surface");
AiNodeSetStr(shader1, "name", "myshader1");
AiNodeSetRGB(shader1, "base_color", 1.0f, 0.02f, 0.02f);
AiNodeSetFlt(shader1, "specular", 0.05f);
// create a textured standard surface shader
AtNode *shader2 = AiNode("standard_surface");
AiNodeSetStr(shader2, "name", "myshader2");
AiNodeSetRGB(shader2, "base_color", 1.0f, 0.0f, 0.0f);
// create an image shader for texture mapping
AtNode *image = AiNode("image");
AiNodeSetStr(image, "name", "myimage");
AiNodeSetStr(image, "filename", "./dad_son.jpg");
AiNodeSetFlt(image, "sscale", 4.f);
AiNodeSetFlt(image, "tscale", 4.f);
// link the output of the image shader to the color input of the surface shader
AiNodeLink(image, "base_color", shader2);
// assign the shaders to the geometric objects
AiNodeSetPtr(sph, "shader", shader1);
AiNodeSetPtr(mesh, "shader", shader2);
// create a perspective camera
AtNode *camera = AiNode("persp_camera");
AiNodeSetStr(camera, "name", "mycamera");
// position the camera (alternatively you can set 'matrix')
AiNodeSetVec(camera, "position", 0.f, 10.f, 35.f);
AiNodeSetVec(camera, "look_at", 0.f, 3.f, 0.f);
AiNodeSetFlt(camera, "fov", 45.f);
// create a point light source
AtNode *light = AiNode("point_light");
AiNodeSetStr(light, "name", "mylight");
// position the light (alternatively use 'matrix')
AiNodeSetVec(light, "position", 15.f, 30.f, 15.f);
AiNodeSetFlt(light, "intensity", 4500.f); // alternatively, use 'exposure'
AiNodeSetFlt(light, "radius", 4.f); // for soft shadows
// get the global options node and set some options
AtNode *options = AiUniverseGetOptions();
AiNodeSetInt(options, "AA_samples", 8);
AiNodeSetInt(options, "xres", 1480);
AiNodeSetInt(options, "yres", 1360);
AiNodeSetInt(options, "GI_diffuse_depth", 4);
// set the active camera (optional, since there is only one camera)
AiNodeSetPtr(options, "camera", camera);
// create an output driver node
AtNode *driver = AiNode("driver_jpeg");
AiNodeSetStr(driver, "name", "mydriver");
AiNodeSetStr(driver, "filename", "./scene1.jpg");
// create a gaussian filter node
AtNode *filter = AiNode("gaussian_filter");
AiNodeSetStr(filter, "name", "myfilter");
// assign the driver and filter to the main (beauty) AOV,
// which is called "RGBA" and is of type RGBA
AtArray *outputs_array = AiArrayAllocate(1, 1, AI_TYPE_STRING);
AiArraySetStr(outputs_array, 0, "RGBA RGBA myfilter mydriver");
AiNodeSetArray(options, "outputs", outputs_array);
// finally, render the image!
AiRender(AI_RENDER_MODE_CAMERA);
SFMLWindow arnoldWindow = SFMLWindow();
arnoldWindow.show(outputs_array);
// ... or you can write out an .ass file instead
//AiASSWrite("scene1.ass", AI_NODE_ALL, FALSE);
// Arnold session shutdown
AiEnd();
return 0;
The Arnold plugins (like MtoA) have a custom Arnold driver that writes the the display window.
Here's the SItoA driver:
https://github.com/Autodesk/sitoa/blob/master/plugins/sitoa/renderer/DisplayDriver.cpp
Thank you. I am new to C++, and my question really is how to use it with SFML. I come from a Python and Java background.
Then you can use the Arnold Python API to build the scene and render.
If you want to show the final rendered image, you just load the rendered file from disk.
