i read the spherical camera description in the arnold manual.
there is the following sentence.
"To get the full spherical range, the camera's screen window must be set to [-1,-1] to [1,1]."
where is the camera's screen window?
In Maya you will find this in the Extra attributes section of the camera node in the attribute editor
You will need to click "Add New Item" under each entry.
The default for the sphereical_camera is [-1,-1] to [1,1], so you should need to change any settings.
