Arnold General Rendering Forum
C4DtoA - Licence for team render machines
2 ANTWORTEN 2
Nachricht 1 von 3
simonEPZ3S
795 Aufrufe, 2 Antworten
Hoping someone can clarify things as I have looked here on the forums and on the web and not found a clear answer.
I am currently using the trial version but hope to purchase a single user licence in the near future. I believe the trial does not support team render so i don't think i am able to test.
I have a few spare machines that I would like to use as a small render farm.
Questions are...
Do I need to purchase a licence for each of the team render machines?
Is there a limit on the amount of machines I can use?
Can I have team machines that are both Windows and OSX?
Thanks for any insight.
Tags (2)
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: simonEPZ3S
  • You can use the trial and some unlicensed copies of Arnold to test Team Render. You'll just get a watermark, that's all.
  • You need an Arnold license for each machine.
  • You can use any machines as you have Arnold licenses. There's no limit imposed by Arnold.
  • You can have a mix of machines. I think the only difficulty would be dealing with paths if you want to keep assets on a separate file server instead of letting TeamRender copy them locally.
https://docs.arnoldrenderer.com/x/DAFeAg
You Will Require an Arnold License for Each Team Render Client
Every machine that renders with Arnold needs an Arnold license.
https://docs.arnoldrenderer.com/display/A5AILIC/Licensing+Home
Render farm licensing
Every node on a render farm needs an Arnold license. This includes TeamRender clients for CINEMA 4D.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
simonEPZ3S
Thanks for the info and links Stephen.
I was worried that would be the case. I guess I have been a bit spoiled with Corona as it is about £200 cheaper and includes 3 render nodes.
Not sure why there is such a big price difference between the US and UK store for Arnold either. The difference is way more than an exchange rate thing.
