From what distance? Do you see the whole planet? Are you inside of the atmosphere? Please be more specific.
Yes, can you provide some more information or image examples of what you want to achieve. Which plugin you are using would also be helpful.
You could follow this tutorial.
There is also a rim lighting example here.
@Lee Griggs @Zeno Pelgrims
https://www.solidangle.com/news/gravity/
I know that the shader tree for creating this realistic atmosphere must be far more complex than simple rim lighting or the Earth tutorial, I'm just wondering how the FX dept used Arnold to create such a realistic one. Thanks.
From the Solid Angle website:
"The rendering of the earth asset was another challenge and one of our lead shader writers, Nathan Walster, developed a volumetric approach (which raymarched the atmosphere, clouds and terrain data set) building on a variety of Framestore tools, such as our volume file format (fVox) and FX rendering tool (fMote)."
I don't remember if there was, but maybe there is also something in Cinefex about it.
I use aiStandardSurface Transmission Scatter for this project for atmosphere
Rendering one high res frame, and use them like matte paint for all sequence
Because it is easily remapping with ramp in render, for deeper values at the edges of the planet, and for tone transitions from brighter to darker blue...
This is not the best example, but the meaning should be clear, you anyway will use volume for atmosphere effect, question is just how convenient it will be do it ...
With maya fluid, or convert geometry to vdb, or maybe using polygon to volume in arnold, or transmission scatter in StandartSurface shader ...
The latter option most simple and effective for the atmosphere, but it not work, if camera move through the atmosphere.
To build on @Slava Sych's suggestion to use a polygon as a volume in Arnold, I think that would be the simplest solution for a situation where you would need to actually enter the atmosphere or have objects moving through it. One glaring issue to this, however, is that earth's atmospheric density has an exponential falloff as you move further from the surface. Is there any way to replicate this using the Arnold Standard Volume shader? I can't seem to get a ramp connected in any way to density or figure out a solution using displacement.
Is there some sort of way to control the density via a ramp from the core to the edge of a polygon volume?
I managed to do the density changes by getting the current shader state of the voxel being rendered in local space. I then used some math nodes with some additional information about the size of the atmosphere, and made it normalize to a 0...1 range, which I then used as uv coirdinates in a 16 bit grey scale texture, made from real density values at varying heights. I then fed this into the density with a little multiplier node attached. Works perfectly.
Here’s some pseudo math for you:
(Length(local voxel pos)-minRadiusAtmosphere) / thicknessAtmosphere
