When I start Arnold render Maya stuck and is not responding.
If I remove xgen fur from the scene (remove layer) render works perfectly. Add fur back - doesn't work. Both CPU and GPU. With two different powerful PCs.
Maya 2022.3, mtoa 5.0.0.3
The same scene with fur is rendered well with two laptops without GPU on board.
What does the Arnold log say?
Hi Christoph, thanks. It says nothing, cause of stuck. Maya doesn't respond and I close the task with the manager. This problem doesn't come to the log file. Then I start Maya and it works well until I try the render with the fur again.
If you don't see any Arnold log, then the render never started.
You can send the Arnold log to a file, and you can see the Arnold log in the Maya Output Window.
Also, you can start Maya from the command line, and use the -log flag to send the Maya log to a file.
