00:00:00 123MB | log started Sat Sep 9 14:45:54 2023
00:00:00 119MB | Arnold 7.2.3.2 [de1f0af4] windows x86_64 clang-15.0.7 oiio-2.4.1 osl-1.12.9 vdb-7.1.1 adlsdk-7.4.2.47 clmhub-3.1.1.43 rlm-14.2.5 optix-6.6.0 2023/08/29 02:53:16
00:00:00 119MB | running on Razer-Blade, pid=15588
00:00:00 119MB | 1 x 11th Gen Intel(R) Core(TM) i9-11900H @ 2.50GHz (8 cores, 16 logical) with 32515MB
00:00:00 119MB | NVIDIA driver version 536.99 (Optix 60806)
00:00:00 119MB | GPU 0: NVIDIA GeForce RTX 3080 Laptop GPU @ 1245MHz (compute 8.6) with 16383MB (16191MB available) (NVLink:0)
00:00:00 119MB | Windows 10 (version 10.0, build 22621)
00:00:00 119MB | soft limit for open files is set at 2048
00:00:00 119MB |
00:00:00 125MB |
00:00:00 125MB | authorizing with license managers: user, network ...
00:00:01 132MB | [user] authorized user "mats_tegner" in 0:01.65
00:00:01 132MB | [user] TRIAL expiration date: 2023-10-06T13:42:27+02:00
00:00:01 132MB |
00:00:01 132MB | [color_manager] using color manager of type "color_manager_ocio"
00:00:01 133MB | [color_manager_ocio] using config file C:\Users\m_teg\solidangle\Arnold-7.2.3.2-windows\bin\../ocio/configs/arnold/config.ocio
00:00:01 133MB | [color_manager] rendering color space is "ACEScg"
00:00:01 186MB |
00:00:01 186MB | there are 1 light and 3 objects:
00:00:01 186MB | 1 persp_camera
00:00:01 186MB | 1 point_light
00:00:01 186MB | 1 image
00:00:01 186MB | 2 utility
00:00:01 186MB | 2 standard_surface
00:00:01 186MB | 1 driver_jpeg
00:00:01 186MB | 2 box_filter
00:00:01 186MB | 1 gaussian_filter
00:00:01 186MB | 1 sphere
00:00:01 186MB | 1 polymesh
00:00:01 186MB | 2 list_aggregate
00:00:01 186MB | 2 color_manager_ocio
00:00:01 186MB |
00:00:01 186MB | rendering image at 480 x 360, 8 AA samples
00:00:01 186MB | AA samples max <disabled>
00:00:01 186MB | AA sample clamp <disabled>
00:00:01 186MB | diffuse samples 2 / depth 4
00:00:01 186MB | specular <disabled by depth>
00:00:01 186MB | transmission samples 2 / depth 2
00:00:01 186MB | volume indirect <disabled by depth>
00:00:01 186MB | total depth 10
00:00:01 186MB | bssrdf samples 2
00:00:01 186MB | light <using per light samples>
00:00:01 186MB | transparency depth 10
00:00:01 186MB | initializing 14 nodes
00:00:01 187MB | creating root object list ...
00:00:01 187MB | node initialization done in 0:00.00 (multithreaded)
00:00:01 188MB | updating 15 nodes
00:00:01 189MB | mylight: point_light using 1 sample, 2 volume samples
00:00:01 193MB | scene bounds: (-10 0 -10) -> (10 8 10)
00:00:01 193MB | node update done in 0:00.00 (multithreaded)
00:00:01 193MB | [aov] parsing 1 output statements ...
00:00:01 193MB | [aov] registered driver: "mydriver" (driver_jpeg)
00:00:01 193MB | [aov] * "RGBA" of type RGBA filtered by "myfilter" (gaussian_filter)
00:00:01 193MB | [aov] done preparing 2 AOVs for 1 output to 1 driver (0 deep AOVs)
00:00:01 197MB | starting 16 bucket workers of size 64x64 ...
00:00:01 261MB | [accel] list_aggregate bvh4 done - 0:00.00 (wall time) - 2 prims, 1 key
00:00:01 273MB ERROR | [texturesys] myimage: Could not open file "arnold.png"
Invalid image file "arnold.png": Could not open file "arnold.png"
00:00:01 273MB ERROR | [texturesys] myimage: Invalid image file "arnold.png": Could not open file "arnold.png"
00:00:01 274MB ERROR | [texturesys] myimage: Invalid image file "arnold.png": Could not open file "arnold.png"
00:00:01 274MB WARNING | render terminating early: received abort signal
00:00:01 274MB | render done in 0:00.011
00:00:01 274MB | [driver_jpeg] writing file `scene1.jpg'
00:00:01 208MB | render done
00:00:01 209MB |
00:00:01 209MB | releasing resources
00:00:01 146MB |
00:00:01 146MB | releasing resources
00:00:01 137MB | unloading 3 plugins
00:00:01 137MB | closing alembic_proc.dll ...
00:00:01 137MB | closing cryptomatte.dll ...
00:00:01 137MB | closing usd_proc.dll ...
00:00:01 131MB | unloading plugins done
00:00:02 131MB | Arnold shutdown
Where is the arnold.png located?
Gelöst! Gehe zur Lösung
Gelöst von mats_tegner. Gehe zur Lösung
There is a typo in the example given in the docs. The correct filename is arnold_icon.png which can be found in the bin directory of the Arnold SDK.
