Arnold General Rendering Forum
Arnold -render passes / masks problem
2 ANTWORTEN 2
Nachricht 1 von 3
Tomasz_Laskowski
290 Aufrufe, 2 Antworten
Hey Guys,
I've got a problem, trying to make masks for postproduction in photoshop. I made two tutorials from YT and I didn't manage to solve the problem with AOV's. In the Frame Buffer i can't rollaout menu regarding object_ID. Did anyone have the same or similar issue? I spend like 2.5h , and still can't solve the problem.
Links to tutorials:
https://www.youtube.com/watch?v=UUMYXTDeyxc
https://www.youtube.com/watch?v=oTbcydc1WkQ
Tags (1)
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
CiroCardoso3v
als Antwort auf: Tomasz_Laskowski
Hi Tomasz,
Use the Arnold Render View to check the AOVs. You can find that on the Arnold Menu.
If you are working with Photoshop, I still recommend you using Cryptomatte and install the EXR-IO plugging to open those exr files. You don't need the Object ID with this workflow.
https://www.exr-io.com/
Lead Enviroment Artist @Axis Studios
Arnold Discord Server
Ciro Cardoso
Nachricht 3 von 3
Thanku You for your fast response! :leicht_lächelndes_Gesicht:
Finaly i managed to rollout this menu with object_id, but i can do this only in active shade mode, unfortunately there are is no picture, just a black screen. On regular Virtual Frame Buffer and in the Arnold Render View the object_id rollout doesn't exist...
