Arnold General Rendering Forum
Arnold Mesh Volume tag back to mesh to shade with toon
5 ANTWORTEN 5
Nachricht 1 von 6
450 Aufrufe, 5 Antworten
https://docs.arnoldrenderer.com/display/A5AFMUG/Polymesh+to+Volume
can i convert this back to a mesh so i can shade it with toon? @
Tags (2)
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
lee_griggs
als Antwort auf: Anonymous
This would be nice but isn't possible.
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 3 von 6
als Antwort auf: lee_griggs
Ah :verwirrtes_Gesicht:
thank you griggs, you are an alchemist!
Nachricht 4 von 6
would be possible to use a plane on front of the volume (like the refractive portraitst) as a "filter" and apply the contour to it? @
Nachricht 5 von 6
lee_griggs
I don't believe it will work, but might be worth a try! If it works, please post the results!
Lee Griggs
AUTODESK
Nachricht 6 von 6
schwungsau
you do almost the same effect in Houdini and generate a mesh with it for toonn rendering. way simple than baking a volume shader displacment.
