I'm trying to use Arnold License Manager with single-user licensing on Ubuntu 20.04.1.
Installing single-user licensing fails with the following error message:
The relevant lines from InstallationLog.txt are as follows:
2020-10-01 13:56:10 ERROR | single user licensing install failed: (10012) Single-user licensing install failed: (3) [22317] Warning: QSslSocket: cannot call unresolved function CRYPTO_num_locks [22318] Warning: QSslSocket: cannot call unresolved function CRYPTO_set_id_callback [22318] Warning: QSslSocket: cannot call unresolved function CRYPTO_set_locking_callback [22318] Warning: QSslSocket: cannot call unresolved function ERR_free_strings qt.network.ssl: QSslSocket: cannot resolve CRYPTO_num_locks qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_id_callback qt.network.ssl: QSslSocket: cannot resolve CRYPTO_set_locking_callback qt.network.ssl: QSslSocket: cannot resolve ERR_free_strings qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_cleanup qt.network.ssl: QSslSocket: cannot resolve EVP_CIPHER_CTX_init qt.network.ssl: QSslSocket: cannot resolve sk_new_null qt.network.ssl: QSslSocket: cannot resolve sk_push qt.network.ssl: QSslSocket: cannot resolve sk_free qt.network.ssl: QSslSocket: cannot resolve sk_num qt.network.ssl: QSslSocket: cannot resolve sk_pop_free qt.network.ssl: QSslSocket: cannot resolve sk_value qt.network.ssl: QSslSocket: cannot resolve SSL_library_init qt.network.ssl: QSslSocket: cannot resolve SSL_load_error_strings qt.network.ssl: QSslSocket: cannot resolve SSL_get_ex_new_index qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method qt.network.ssl: QSslSocket: cannot resolve SSLv3_client_method qt.network.ssl: QSslSocket: cannot resolve SSLv23_client_method qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method qt.network.ssl: QSslSocket: cannot resolve SSLv3_server_method qt.network.ssl: QSslSocket: cannot resolve SSLv23_server_method qt.network.ssl: QSslSocket: cannot resolve X509_STORE_CTX_get_chain qt.network.ssl: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_noconf qt.network.ssl: QSslSocket: cannot resolve OPENSSL_add_all_algorithms_conf qt.network.ssl: QSslSocket: cannot resolve SSLeay qt.network.ssl: QSslSocket: cannot resolve SSLeay_version qt.network.ssl: QSslSocket: cannot call unresolved function CRYPTO_num_locks qt.network.ssl: QSslSocket: cannot call unresolved function CRYPTO_set_id_callback qt.network.ssl: QSslSocket: cannot call unresolved function CRYPTO_set_locking_callback qt.network.ssl: QSslSocket: cannot call unresolved function SSL_library_init Cannot register file downloader for https protocol: QSslSocket::supportsSsl() returns false
I have openssl version 1.1.1f installed. My Arnold version is 6.0.4.0, with htoa version 5.4.0.
It seems like the version of Qt used to build the license manager needs updating in order to be compatible with the most recent version of openssl.
If anyone is having the same problem I fixed it by installing the "alien" package on ubuntu. Apparently it is needed for the install.sh file to run.
@mats_nyman is correct
The Autodesk Licensing tools are RPM packages, so on Debian based distributions (Ubuntu, Mint etc) you will need to install the alien package which will allow the Arnold licensing installer to convert the rpm packages to deb and install them.
Hiya, I'm going insane!
Could someone please provide a step by step guide on how to do this install. I have alien.
Do I need to uninstall HtoA and reinstall with alien?
Thank you in advance!
