Arnold General Rendering Forum
Arnold Kick gets stuck during render
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
davidAZX57
445 Aufrufe, 2 Antworten
Hi
I'm having a lot of issues where I set a render going and Arnold will render through the 10%, 15%, 20% and at some point get stuck and just stop moving. If I hit ESC suddenly it springs back to life and continues rendering. This is most frustrating when you render overnight and return in the morning to see little progress. Any ideas? Is this a known thing?
Grateful for any help / advice
Thank you
David
Tags (2)
Beschriftungen (2)
2 ANTWORTEN 2
Nachricht 2 von 3
Stephen.Blair
als Antwort auf: davidAZX57
I've seen it once or twice myself, but I haven't had any support cases about it.
Maybe try using cmd /c to run the batch file, or to run the kick command?
And redirect all output to a log file with >>
Seems like it could be a general Windows thing:
https://superuser.com/questions/312132/command-prompt-hangs-until-keypress
https://github.com/microsoft/terminal/issues/3736
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 3
davidAZX57
Thanks Stephen, that sounds logical, i'll investigate down that route thank you
