Hey,
I still try to properly understand how to use the denoising feature in Arnold. For lookdev I use the Oidn a lot and it gives great and fast results. I also used it for sequences with the batch render, even though its not really made for animations. But it is easy to use: just add the denoiser, select the layers I want to have denoised and thats it.
I have troubles understanding noice: I followed Lee Griggs video on Youtube (https://www.youtube.com/watch?v=eV7N_ymSjwM) and made a test sequence to test the noice utility with rendered .exr sequences.
- Why is there a noice imager in the Arnold RenderView? I thought noice is a tool that is used afterwards. What does it do? Do i need to turn it on when I want to properly denoise afterwards or does it denoise every render right after its done when rendering a batch sequence
- A question a lot of people have: How do we use noice when we want to denoise specific passes? I also followed Rezas video on how to use noice (https://www.youtube.com/watch?v=YSAcFE_x-Ds&t=749s), have the "Output Denoising AOVs on. When I load my rendered .exr in noice, I still get only RGBA.
It would be awesome if someone could explain, maybe even doing a proper workflow tutorial so everyone can catch up and understands on how to use noice with seperate AOVs. I know that it is possible somehow.
Arnold can be super slow and people complain a lot about high render times, even thinking about switching render engines. I think using noice can be a real gamechanger if used properly.
Gelöst! Gehe zur Lösung
Gelöst von meU6KLN. Gehe zur Lösung
Hi meU6KLN, Noice in the Arnold RenderView window is purely for denoising still images (see top here): https://docs.arnoldrenderer.com/display/A5AFMUG/Arnold+Denoiser
Do you have 'merge AOVs' enabled in the common tab for EXR?
Information about Output Denoising AOVs can be found here:
https://docs.arnoldrenderer.com/display/A5AFMUG/AOVs#AOVs-OutputDenoisingAOVs
The workflow is here:
Ah, I see!
"The Arnold Denoiser requires that the parameter "Output Variance AOVs" is enabled in the Render Settings AOVs tab (Output Denoising AOVs)."
I had trouble with creating the Output Driver for each AOV layer and didn't knew that I have to tell Arnold Denoiser (noice) to denoise RGBA / coat / diffuse / specular / sss / transmission - layers in the Light Group AOV input.
This link was very good to understand what and how to do: https://support.superrendersfarm.com/hc/en-us/articles/360062299040-maya-arnold-denoiser !
