Arnold General Rendering Forum
Arnold C++ API of "kick -nodes"
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
429 Aufrufe, 3 Antworten
Hi all,
My google-fu is failing me - anyone happen to know what the Arnold C++ API to list all the loaded nodes is?
i.e. the thing that's probably called under the hook when you execute "kick -nodes"
Cheers,
Alan.
Tags (1)
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
Stephen.Blair
als Antwort auf: Anonymous
Here's the Python from the old pykick. The C++ is basically the same calls...
def PrintRangeOfNodes(first, sort):
   nodes = []
   i = 0
   it = AiUniverseGetNodeEntryIterator(AI_NODE_ALL)
   # skip first node entries to start on the specified one
   while not AiNodeEntryIteratorFinished(it) and i < first:
      AiNodeEntryIteratorGetNext(it)
      i += 1
   while not AiNodeEntryIteratorFinished(it):
      nentry   = AiNodeEntryIteratorGetNext(it)
      nodename = AiNodeEntryGetName(nentry)
      typename = AiNodeEntryGetTypeName(nentry)
      nodes.append([nodename, typename])
   AiNodeEntryIteratorDestroy(it)
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 4
thiago.ize
You'll want to use the AiUniverseGetNodeEntryIterator(AI_NODE_ALL) to get an iterator that lets you examine all the node types. The you call AiNodeEntryIteratorGetNext() on the iterator to get an AtNodeEntry which you can then pass to AiNodeEntryGetName(), AiNodeEntryGetTypeName, etc. to get information on these nodes. Take a look at the doxygen/headers included in the Arnold SDK to get info on all these functions. Hopefully this helps?
Nachricht 4 von 4
Thanks, @Stephen Blair and @Thiago Ize - most appreciated.
