Arnold General Rendering Forum
Arnold 5.2.0.0 SDK Sheen Bug
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
1234 Aufrufe, 8 Antworten
It appears sheen will not render through the Standard Surface Shader, is there any extra setup necessary to have this render? It works in Maya, but will not render from the SDK.
Beschriftungen (3)
8 ANTWORTEN 8
Nachricht 2 von 9
Stephen.Blair
als Antwort auf: Anonymous
So if you export an ASS file from Maya, it doesn't work? Please post a repro.
// Stephen Blair
// Arnold Renderer Support
Nachricht 3 von 9
als Antwort auf: Stephen.Blair
It's for the plugin I'm developing for Arnold to work in Blender, set up the same as all the other standard surface parameters, and exported the ASS file from Blender and imported into Maya, and appears Sheen is not working that way either.
Nachricht 4 von 9
Stephen.Blair
Please post an ass file
There's no extra setup required, you just adjust the sheen parameters. I can see a change in the render in Maya by changing Sheen intensity
// Stephen Blair
Nachricht 5 von 9
Nachricht 6 von 9
Stephen.Blair
standard_surface.sheen is not set, so the sheen weight defaults to 0
kick -info standard_surface.sheen
 node: standard_surface  param: sheen  type: FLOAT  default: 0
Try with standard_surface.sheen 1
// Stephen Blair
Nachricht 7 von 9
Sheen? The docs only stated `sheen_weight` `sheen_color` and `sheen_roughness`
Does `sheen_weight` need to be changed to `sheen`? Which would make more sense, being consistent with the rest of the parameters for standard_surface
Nachricht 8 von 9
@Stephen Blair can confirm changing `sheen_weight` to `sheen` worked, not entirely sure what the purpose of `sheen_weight` is though. Maybe update the docs? Thanks for your help Stephen.
Nachricht 9 von 9
Stephen.Blair
kick -info standard_surface is the definitive reference for built-in parameters
// Stephen Blair
