Hello again! I finally made it through the docs and I noticed in the final PDF archive page that the modifications and the corresponding date of change are listed. This is extremely helpful and I am very grateful that this information is provided.
I was wondering if the online and offline versions are edited simultaneously. I ask because I just finished making an offline version based on the online docs. I opted to do this since I wanted to have all the gifs, rollovers, and use iframes embedded and so that I could add additional information to the pages.
Everything worked outvery well; but now I just have to keep it current. So, I’m assuming that if I just go and recopy the page that has been designated as altered from the online docs, the changes will be reflected there as well as the PDF. Obviously I will know the answer to this question through experience eventually, but figured I would double check to get a more general answer.
Thanks for the help! Arnold is awesome!
Gelöst! Gehe zur Lösung
Gelöst von Stephen.Blair. Gehe zur Lösung
No, the pdf files are exported periodically (eg for major releases), while the online documentation is updated continuously.
Makes sense. I probably should have been able to figure that out. I definitely really appreciate the quality information. It is good to know for sure. Thank you very much!
