Arnold General Rendering Forum
Anold mix shader produces purple render
2 ANTWORTEN 2
Nachricht 1 von 3
275 Aufrufe, 2 Antworten
When i use two separate shaders (both are standard surface shaders) and i try to use mix shader node i get a purple render.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Nachricht 3 von 3
lee_griggs
Does it render purple with just the Standard Surface shaders?
Maybe the Layer shader and/or Layer texture would work better in this case?
Can you upload a simplified example scene?
Lee Griggs
Arnold rendering specialist
AUTODESK
