Arnold General Rendering Forum
An issue with glass material shader
7 ANTWORTEN 7
Nachricht 1 von 8
659 Aufrufe, 7 Antworten
red-glass-ball-in-a-glass-ball.zip
Hi all,
I am trying to make a model of red glass ball in a transparent glass ball.
But for some reason that I don't know, it's not transparent like a real glass.
Though I can see a red glass ball, I cannot see the reddish background through the glass ball.
All parameters were set as recommended by Arnold tutorial, I think.
Do you have any idea?
Thank you.
Tags (1)
Beschriftungen (1)
7 ANTWORTEN 7
Nachricht 2 von 8
madsd
als Antwort auf: Anonymous
@Hojeong Yu
Like this? in case, yes. Attached a max 2016 file.
Nachricht 3 von 8
als Antwort auf: madsd
Hi Mads,
YES! It's exactly what I wanted. What is the secret of your magic?
Could you give some transparency on the red ball?
Thank you!
Nachricht 4 von 8
madsd
Attached updated scene again max 2016, the red ball is now receptable to background changes, as it's more transparent. Use the opacity to introduce stronger or weaker effect.
Nachricht 5 von 8
1. Did you use the "Opacity(cutout)" tab in your Max? If not, could you let me know which tab (or control panel) you used for the control of opacity? I am using Max 2019.
2. After rendering I found that the red ball has some speckles. Do you have any idea to have clear surface?
Thank you so much Mads!
Nachricht 6 von 8
madsd
Correct, Opacity Cutout does the trick, while not destroying reflections, a bit of calibration needed to get the amount of transparency you want.
You want to render longer, then the specs goes away, the file I send you cleans up after a while.
Nachricht 7 von 8
Got it. Thank you so much Mads.
You're really helpful!!
Have a great day/
Nachricht 8 von 8
madsd
You too Hojeong.
