My goal is to create an optimized denoising workflow for AMD Graphics using Arnold (for Maya) and Nuke (possibly).
Premise:
* Arnold has 2 denoising apps: CPU and GPU (requires Optix - NVIDIA)
* Nuke is an industry standard, so 99% of studios would have Maya and Nuke.
* Nuke Denoiser can run on AMD GPUs (OpenCL)
* Running a denoiser on GPU is faster than CPU
Question:
I would like to understand if the denoiser in Nuke (which has OpenCL capabilities) could be utilized to efficiently replace the non-existing option provided with Arnold to run a denoising algorithm on AMD Graphics.
In other words, I would like to understand if the 'noice' app provided by Arnold equally works on 2D and 3D images, or it has some specific portion of the algorithms that utilizes 3D information derived by the Arnold renders, and if Nuke similarly denoises the renders with any notion of 3D or additional AOs that can be written as AOVs from the lighting renders.
Case study:
The Nuke denoiser could be part of the denoising workflow and lift this additional step from the lighting TDs to the Compers which could be running as part of their renders utilizing the GPU power.
The Nuke Denoiser takes a sample area of noise which can be fed as separate image so I think I could output a sample render frame from Arnold on a white card, similar to what we do on set when using a color checker card [I would create a 2D plane aligned with the camera with a white shader and using the same render setting generate an image containing the noise sample which I can then feed to Nuke].
How sound is this idea/approach ? Has anybody else used a similar approach ? What are your thoughts about this ? How much performance improvement could I get by running it on a GPU and would it make sense to run it on the final image, or per AOV?
the Nuke Denoiser is the most a terrible solution for renderings in my experience. the Intel Open Image Denoiser is better and much faster with CPU then Nuke Denoiser with a large GPU.
