Arnold General Rendering Forum
A question about the texture for Arnold renderer
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
639 Aufrufe, 5 Antworten
I am trying to make some images that look like the images attached.
Could you give me some tips to make such textures?
Thank you in advance.
Tags (2)
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Hey Buddy,
Take a try the below method.
Create a ramp and a sampler info node. Disconnect the place2dtexture node from ramp and connect the facing ratio attribute to UCoord of Ramp through maya connection editor. Now you can change the color of your ramp according to your need, assign the same ramp textuter to both diffuse and emission of your shader.
You can check the uses of Sampler info node in web.
Nachricht 3 von 6
lee_griggs
You can use a Facing Ratio shader (similar example at bottom).
Lee Griggs
Arnold rendering specialist
AUTODESK
Nachricht 4 von 6
als Antwort auf: lee_griggs
this method is better.
Nachricht 5 von 6
Hey Lee Griggs and Girijashankar Senapati,
Thank you so much!
Nachricht 6 von 6
Thank you so much!
