Capturing a shadow on a matte using a skydomelight but its creating a large shadow all around the model.
The distance is too long for the desired use.
I implemented a light portal and got this
and then tried adding two more light portals and got this
Any ideas what could help solve these issues?
Light Portals should be used for lighting interiors through small windows. Have you tried using an Area light . It might give you more control over the shadows. Alternatively, you could connect a HDRI to the skydomelight that has more directional lighting.
Not really. Try some different ones and experiment to see which ones look best.
Please recommend a google image search, it would be a great push in the right direction
